Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SFE2000 Vlan & routing dhcp requests
Hi there,
Please be gentle I am new to Cisco products and some of what I am trying to acomplish.
I am considering buying an SFE2000 to seperate our network into 2 perhaps 3 VLANS. One of these VLANS will be for guests to access to the internet but not access the company network. We have a SBS2008 server inplace and I would like this server to handle the dhcp requests from the private and guest networks, this bit I am comfortable with BUT can I keep the guest VLAN seperate and forward dhcp requests to our sbs box using the SFE2000 in Layer 3 mode?
If so i would really appreciate any pointers that may help.
Hope that explains it fairly well.
James
Re: SFE2000 Vlan & routing dhcp requests
One way would be to run the switch in layer 2 mode and put 2 NICs in the server, or configure the NIC and TCP/IP stack to support tagged frames.
In layer 3 mode you can configure DHCP relay and multiple DHCP hosts. So that will work.
Thanks for your reply. I bit the bullet and bought the unit it has arrived today so will spend some time configuring it later
768
