SG 300-28 28-Port Gigabit Managed Switch -Lan connectivity issues
Our office lan running on 2 * SG 300-28 28-Port Gigabit Managed Switch.
PID VID:SRW2024-K9 V01
Firmware Version (Active Image):1.0.0.27
The users are seeing there connection to fileservers(mapped network drives) slowing down over the period.
We have to re-boot the offending switch to get the normal traffic back.
I have raised a ticket with cisco small business people and they said to upgrade the firmware to latest version.
But I am wondering why I need to upgrade this switch as the other switch which also brought at the same time with the same spec have no such issues.
Even if I decided to upgrade the firmware, they have recommended that I need to reset the switch to factory settings and try to put the previous configuration manually which is a worry for me.
I have logged on to the web console and I have found out, I can use TFTP or HTTP to backup the config,how do I use those services and what parameters i need to pass those to work, does using that functionality can rollback the switch to previous running configuration?
PS: Both the switch have connected together using a FC trunk with link aggregation eanbled.So how do I get all those settings back if I upgrade/rollback?
I just have to come up with some solution as it is affecting the business, so any help would be much appreciated.
Please see the attachment and let me know if any other info needed?
Thanks in advance,
Suji
Green
Hi Smith, the 1.0.0.27 is the first production release software for this switch.  If you'd like, upgrade to the 1.1.2.0 and give that a try. It should not need a factory reset after the upgrade. Anything later really should need a reset because it changes howeverything works inside.
To make a a backup, log in to the switch HTTP, go to Adminstration ->File Management -> Download/Backup config
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Thanks for the reply.
If I choose HTTP I get 3 options.
first its save action >download or backup.
second Source File name :Browse ?(How do I browse to the source file,I don't think it's possible if I am using the web interface from my local pc)
Third option for Destination file type > Running config or Startup config or backup config
Smith
Hi Tom,
So which one I needed to chose to backup the config? and where from I get the source file name?
Smith
Green
Hi Smith, click the button that says back up.
-Tom
Please see the difference between the connected switches configuration.
Maybe the vlan 10 and 30 has been created wrongly.
Please see the config for both the switches and give me some advice/suggestions.
I really appreciate that.
                              Bad Switch Config
/* This is the config for the bad switch */
interface port-channel 1
flowcontrol auto
exit
interface port-channel 2
description netAppFiler1
exit
interface port-channel 3
description Switch
flowcontrol auto
exit
port jumbo-frame
vlan database
vlan 10,30
exit
interface ethernet g12
switchport trunk native vlan 10
exit
interface ethernet g24
switchport trunk native vlan 30
exit
interface vlan 10
name Private
exit
interface vlan 30
name "Private 2"
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
port-channel load-balance layer-2-3
interface range ethernet g(25-26)
channel-group 2 mode on
exit
interface range ethernet g(27-28)
channel-group 3 mode on
exit
lacp timeout short
exit
interface range ethernet g(1-26)
lacp port-priority 2
exit
ip dhcp relay address 192.168.0.1
ip dhcp relay enable
ip dhcp information option
interface vlan 1
exit
bonjour service enable csco-sb
bonjour service enable http
bonjour service enable https
bonjour service enable ssh
bonjour service enable telnet
hostname switchbad
line console
exec-timeout 0
exit
line ssh
exec-timeout 0
exit
line telnet
exec-timeout 0
exit
username admin password xxxxxxxxxxxxxxxxxxxxxxxxxx level 15 encrypted
no snmp-server enable
snmp-server location "Server Rack"
ip http exec-timeout 0
ip https exec-timeout 0
clock timezone 1
clock dhcp timezone
ip name-server  192.168.0.1 192.168.0.9
snmp-server set rlAutomaticClockSetFromPCEnabled  rlAutomaticClockSetFromPCEnabled true
                         Good Switch Config
/* Good switch run config *
description Switch
flowcontrol auto
exit
port jumbo-frame
lacp system-priority 2
channel-group 1 mode on
exit
lacp timeout short
exit
exit
switchport protected-port
exit
hostname switchbaebf1
line console
exec-timeout 0
exit
line ssh
exec-timeout 0
exit
line telnet
exec-timeout 0
exit
aaa authentication enable Console local
aaa authentication enable SSH local
aaa authentication enable Telnet local
aaa authentication login Console local
aaa authentication login SSH local
aaa authentication login Telnet local
line telnet
login authentication Telnet
enable authentication Telnet
password xxxxxxxxxxxxxxxxx encrypted
exit
line ssh
login authentication SSH
enable authentication SSH
password xxxxxxxxxxxxxxx encrypted
exit
line console
login authentication Console
enable authentication Console
password xxxxxxxxxxxxxx encrypted
exit
username admin password xxxxxxxxxxxxxx level xy encrypted
ip ssh server
snmp-server location "Comms rack"
ip https server
clock summer-time recurring eu
sntp unicast client enable
sntp unicast client poll
sntp broadcast client enable
sntp server xx.yyy.zz.70 poll
sntp server zz.yyy.xx.201 poll
sntp server zz.yy.xxx.2 poll
sntp server xzz.xxx.xy.149 poll
clock dhcp timezone
ip telnet server
Smith
844
