SG 500X Optic support
bijbalaktn
Team ,
can we use SFP-10G-SR-S as a transreceiver for a SG 500X switch ?
-BJK
Yes, these should be fine.
I would suggest that you raise this question with your Cisco reseller at the time of purchase for added  comfort.
7 Replies 7
mattjones03
There is a good explanation here;
https://supportforums.cisco.com/discussion/12583146/difference-between-sfp-10g-sr-s-and-sfp-10g-sr
Thanks for responding Matt.  I did go through it, yes there doesn't seem to be  much difference but  none of the Cisco doc states that the SFP-S is compatible with SG-500X.  Thats my problem.  Coz for one of the projects that I am working on, there is a good number trans receivers required and this SFP-S would bring down the cost considerably.
Let me speak with one of my Cisco partners.
When are you looking to order, as I will mostly not be able to speak with them until Tuesday (UK Time)
Thanks Matt !  The client might decide next week. Tuesday should be fine. Appreciate the help !
Hi Matt / Team,
Any one who could help..
-Bijesh
Thanks Matt, yup, I got a confirmation that these are compatible.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
