SG switches and Microsoft NLB
does anyone know if the SG300 switches can be used with Microsoft NLB in Multicast mode?
I know on traditional Catalyst switches you can statically "map" IP's to mac's and then to multiple ports but this doesn't seem to work correctly on the SG switches - it gives an error about the mac not being not Unicast?
So, any help or links to Cisco SG examples would be appreciated.
thanks
John
Re: SG switches and Microsoft NLB
I have not tested it yet. But I want to know this as well.
Keep in mind that you need to use the multicast MAC Address, not your normal MAC Address. It is bound to a multicast IP Address.
it's the binding of the multicast mac address to a "standard" IPV4 address that gives the problem. Works just fine on an IOS switch.
669
