10-29-2013 08:41 PM
Does tha SG200 need any out of the box hardening, or special security configutations to run safely on the network?
For the question, please assume that there is a cable modem, whicn connects to a router (w/DHCP), which connects to the switch, and then to the computers. I just make to make sure that it isn't opening a "hole" in the network.
Thank you!
Solved! Go to Solution.
10-31-2013 08:34 PM
Hi David, the switch does not "decrease" network security. The switch is essentially as "hard" as your network begins with. You may use additional features such as VLAN's for security purposes as an example if your network can support it.
-Tom
Please mark answered for helpful posts
10-31-2013 05:31 PM
Hello again. Is there any other way to get support from Cisco? This is my first Cisco product, and I don't have some type of service techincal agreement. I'm simply an SMB end user who has a question about using a product that I just purchased. Is this how its normally done at CIsco? Is there a # I can call to ask a question?
Thank you!
10-31-2013 07:41 PM
Hi David,
You have one year warranty support from time of purchase. Please call the Small Business Support Center and speak with an support representative: https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
10-31-2013 07:46 PM
Many thanks for clearing that up!
10-31-2013 08:34 PM
-Tom
10-31-2013 08:41 PM
Thank you. I am learning and I wanted to be safe first. Very much appreciated!
