SG200-50P fan noise problem
Hello, i need help to solve problem with fan control. Sometimes, once per day, the switch start to run fan at full speed. I understood it can be when temperature increase. But running this full speed all the time, only power off helps. Thank you, Marek Ján
Everyone's tags (1)
1 ACCEPTED SOLUTION
Are you running latest
Are you running latest firmware 1.3.7.18 and boot 1.3.5.06?
-- please remember to rate and mark answered helpful posts --
Thanks Brnadon, i have fw 1.3
Thanks Brnadon, i have fw 1.3.1 so i will upgrade to the latest version and we will see. Regards, Marek Ján
Hi, you answer was correct.
Hi, you answer was correct. Now i see Events about fan speed change so it was easy to troubleshoot temperature problem. Thank you, Marek Ján
Hello everyone!
Hello everyone!
Made all updates, but it's still noisy.
Anyone knows fan model-size? Want to replace it with quiet version
Thanks!
Dmitry
709
