sg200-50p noise
I got a switch SG200-50P. From time to time it makes a lot of noise with the fan, just like an airplane motor, it's really anoying.
Is there a way to limit it?
1 REPLY
Silver
Hello,If the fan is just
If the fan is just getting louder because it is going faster then it is probably just because the temperature went up a bit.  Make sure the vents are clear and free or maybe try moving the switch to a cooler location.  However if it sounds unusual like the fan is going to fail or is not working properly go ahead and give us a call at the SBSC so we can troubleshoot a bit further.
Cisco Small Business Support Center Contact Numbers
There isn't a manual way to control the fan speeds.
Hope that helps,
Christopher Ebert - Advanced Network Support Engineer
*please rate helpful posts*
179
