SG200 Small business switch - vlan issue
I have the wonderous task of remotely configuring a few SG200 small business switches.
I need to create a vlan and move a few ports into that vlan, doesn't sound too difficult.
I have created the vlans but when I go to add the ports into the vlan the only option I seem to have is General?
If I specify access I can't say what vlan the port should be in?
What am I doing wrong?
All ports are currently in VLAN 1 and are in mode trunk
I have created 2 new vlans and just want to put 4 ports in VLAN 2 and 4 ports in VLAN 4
Can anyone impart any wisdom?
Roger
Hi Roger,
Did you try this guide?
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=80
Are you configuring it from GUI or CLI ?
Mariusz
Hall of Fame Super Gold
Wrong forum, post in "Small Business switches". You can move your posting with the Actions panel on the right.
271
