Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SG300-10P problem getting all vlans to see the internet
Having a config problem that I've been chasing for a few days.
I have a SG300-10P.
System Information:
System Operational Mode:          L3 Mode
System Description:          SG300-10P 10-Port Gigabit PoE Managed Switch
Firmware Version (Active Image):          1.3.5.58
I have set up 3 vlans
vlan1 default has port GE1 untaged, all other ports excluded (can see the internet, via a direct connected comcast fiber modem)
vlan2 internal desktops, port GE1 tagged ports GE2-8 Untaged, GE9-10 excluded
vlan3 external facing IP address, GE1-8 excluded, GE9-10 untagged
VLAN 1          Static          50.204.xxx.xx           255.255.255.252          Valid
VLAN 2          Static          10.1.10.1           255.255.255.0          Valid
VLAN 3          Static          50.204.xxx.xx           255.255.255.224          Valid
(the x's are for this forum, they represent real numbers in my config but have been changed to protect the innocent)
Destination IP Prefix       Prefix Length               Route Type               Next Hop Router IP Address               Route Owner               Metric               Administrative Distance
0.0.0.0                                   0                        Default                         50.204.xxx.xx                         Default                         1                    1
10.1.10.0                               24                      Local                                                               Directly Connected
50.204.xxx.xx               30                     Local        Directly Connected
I have DHCP configured for the 10.1.10.x address on vlan2 and that work.  From vlan2 and 3 I can ping the Switch with the IP address of vlan1.
I can see the switch externaly on it's IP address, but vlan2 and 3 can not see out.
Am I missing a route, or can I not configure the switch this way? What did I mess up?
Thanks in advance.
Hello Shawn,
I am assuming 50.204.xxx.xxx subnet is assigned to your organization by the ISP. Have you made sure that your ISP has a static route that points the 50.204.xxx.xxx/27 to your VLAN 1 IP? Also, for 10.1.10.x network, do you have a router/firewall that performs NAT? Withoute NAT, the network cannot cross the border of your ISP.
Nagaraja
Hi Nagaraja,
Your reply got me thinking in the right direction.
I had my test computer on the 10.1.10.x VLAN2. Once I moved it to the 50.204.xxx.xxx VLAN3 I could see the external WAN/Internet.
I was assuming the SG300 supported NAT, I now see it doesn't support NAT and will order a router/firewall that does.
Thank you
Shawn
Hello Shawn,
Glad to know that you were able to find a fix. If your query is completely answered, can you please mark the thread as "Answered"?
Nagaraja
379
