Community Member
SG300-28 & SG200-26 VLAN routing
I have a SG300-28 and a SG200-24. Both are running the latest firmware.
I am having some major issues getting mutliple vlans to route across the two switches.
On the SG300 I am in Layer 3 mode. I have configured 4 vlans 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24 and 192.168.4.0/24 (vlan 1-4). Each vlan interface is configured with .1 of the respective vlan.
I have the SG200 connected to the SG300 via the last available port on each switch. They are set to trunk. I have created the VLANS on the SG200.
What I would like to do is set ports 1-4 on the SG200 to VLAN 2. Ports 7-12 on VLAN 3, and the rest on VLAN 4.
First off I am assuming this is possible. I have tried the configuration multiple ways, I've tagged ports, not tagged ports, etc. I'm not sure where to go from here.
1 REPLY
Hello Thomas,
I am assuming you have created these VLANs on the SG300 (not just Layer 3 interfaces) as well. Also, the ports are automatically in Trunk mode. But you need to manually add VLANs that need to be tagged on those ports.
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=78
If you have done all these steps, can you please be more specific on the issues you are facing?
Nagaraja
290
