SG300-28 uplink to another SG300-28
Can I connect a single Cat5e cable between two SG300-28 and link them?  If so what must I configure?
1 REPLY
Re: SG300-28 uplink to another SG300-28
Yes, you can. But if there is a longer distance in between you need to use a Cat 6 instead to get 1GB. But you might get away with it.
And by just connecting you have a Layer 2 switch connection. If you need more (e.g routing) it all depends on what you are trying to achieve.
1248
