10-15-2013 10:30 AM
Hi all,
I have a switch that has an unusable web interface. only have arrows / bullet's showing there is a menu item there, but no way to know what each menu item is... unable to apply a firmware update to it since I can't see the menus.
I have the device in "default" ship mode supposedly, the light is blinking constantly telling me this, but the switch is unusable until I can configure it for the network again.
How can I reset the web menu?
Julie
10-15-2013 12:42 PM
So telnet probably isn't enabled but the console port should be enabled by default (I would think). Maybe you can connect to the console port and view your boot images:
SW-SG300-28-1#show bootvar
Image Filename Version Date Status
1 image-1 1.2.9.44 30-Sep-2012 01:33:07 Not active
2 image-2 1.3.0.62 02-May-2013 14:55:01 Active*
if you have a different image or even just a different image of the same file.
SW-SG300-28-1#boot system image-1
SW-SG300-28-1#15-Oct-2013 15:38:28 %COPY-I-IMGSWAP: Actual image swapping takes places ONLY during graceful shutdown
and then
SW-SG300-28-1#reboot
10-15-2013 04:17 PM
Thanks Viningele,
I will locate the console cable tomorrow and give this a try - makes sense that this is worth trying.
I will let you know what the results are when done.
Julie
