SG300-28P Firmware upgrade error -
Greeting's I downloaded Sx300_FW_Boot_1.4.0.88 firmware upgrade for SG300-28P switch. The MD5 checksum of the file matches as listed on Cisco, However when I am uploading the firmware (.ros file) to the switch I get error message:
Bytes Transferred: 7011840
Status: Copy failed
Error Message: Copy: SW code file is over sized
Anyone else having the same problem? Any workarounds?
Thank You!
Parth.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Bronze
 Hi,I like to suggest to
I like to suggest to upgrade the bootloader file(sx300_boot-13506.rfb) first before attempting the firmware. Bootloader can be found on the same zip folder as the firmware.you can use TFTP server to upgrade the boot loader.
Cisco SG300 WEB interface > Administration>File Managment> TFTP .... when you select TFTP the radio button for the "BOOT" fw is now available. Just type in the name of the file and it should load the boot firmware.
regards
Moorthy
Bronze
Hi, You need to carry out an
You need to carry out an interim firmware upgrade to the previous version. Then upgrade to 1.4.X.X. The switch flash file system was changed in 1.3.7.18
regards
Moorthy
Thank You, Moorthy. Pardon me
Thank You, Moorthy. Pardon me for not mentioning this detain in the initial post. The switch however is running 1.3.7.18 currently. It is the active image.
Parth
Bronze
regards
Moorthy
You need upgrade bootrom to
You need upgrade bootrom to be able to go past 1.3.7.18.  When going to 1.3.7.18 it is recommended in release notes to do this for this reason.
-- please remember to rate and mark answered helpful posts --
For reference here are the
For reference here are the relevant notes:
Change in Flash file system
In versions 1.3.5 and later, the Flash file system has been upgraded. This has
implications when upgrading from previous releases to version 1.3.5, and
when downgrading from 1.3.5 or later to previous versions as described
below.
Upgrading from previous releases
During the first bootup of the new version, the flash file system is upgraded. Note
that:
This process takes a few minutes. “…” progress in the Console will be
displayed during this process (not relevant to Sx200).
The syslog file is deleted during this process.
The original image file is deleted. The two images on the Flash after the
upgrade will have the same version.
NOTE Before upgrading to version 1.3.5 and later, the boot loader also needs to be
updated.
If version 1.3.5 or later is installed using the original boot loader, the file system will
not be upgraded, and in the future the user will not be allowed to upgrade to
versions higher than 1.3.5.
4410
