Community Member
Sg300-28P updated firmware no ports active
           I updated the firmware to the latest version. Reset the switch after the bios update. The only problem I have now is none of the gi ports are active. I can get into the CLI. What command do I need to activate all the ports. It says links are down.
1 REPLY
Green
Hi Paul, you can use the command set interface active or you can try to config t , interface range x - x and no shut.
If that doesn't work you may want to call the SBSC to investigate.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
262
