08-07-2012 07:59 AM
I'am testing a sg300 switch in layer 3 mode and created different vlans
vlan1: 172.16.0.0/16
vlan4: 192.168.4.0/24
I inserted a default route to our internet router (172.16.0.55) and there a route back to the switch 172.16.2.101
I defined no acls at the moment
I can access the internet from a client 192.168.4.10 over the router 172.16.0.55
If I ping our DNS server (172.16.0.6) from this client in VLAN4 I get the replies on the client (see picture)
If i ping the router on the client in VLAN 4 I get no replies, sometimes one reply (see picture).
I mirrored the uplink to the different switch where the router is connectd and I can see the replies on wireshark. But somehow they do not get routed to the client on VLAN4 (see picture)
Does somebody have any idea why that happens?
Kind regard
Andreas
08-07-2012 08:54 AM
Hi Andreas,
I feel the information provided is incomplete. I think you have almost all pieces of the puzzle though. Here are the requirements to make this work;
Switch configuration
Router configuration;
-Tom
08-08-2012 12:00 AM
Hi Tom,
thanks for your answer.
I did the most steps you mentioned except
- Set a global default gateway (config t, ip default-gateway 172.16.0.55)
I used a default route like you described too.
- Assign an uplink for Vlan 1untagged, vlan 4 tagged
VLAN4 should only be on this switch but should have the possibility to use the internet
And Internet over the router 172.16.0.55 is working well. But the pings to 172.16.0.55 are not routed back. I can see them on the trunk port on VLAN1 but not on VLAN4.
Kind regard
Andreas
08-08-2012 08:59 AM
Hi Andreas,
I'm not sure I understand.
So if I interpret this correctly, the 172.16.0.0 (vlan 1) network is not known to the switch while the 192.168.4.0 network is.
I understand you have vlan 1 and 4 on the switch. It sounds like you don't have vlan 1 ip interface defined.
If both IP interfaces are defined on the switch the ip route will populate with a directed connected notation.
So I will assume this is the switch configuration;
set system mode router
reload
y
config t
vlan database
vlan 4
int vlan 1
ip address 172.16.2.101 /16
int vlan 4
ip address 192.168.4.x /24
interface gi1
switchport mode trunk
switchport trunk allowed vlan add 4
interface gi2
switchport trunk native vlan 1
interface gi3
switchport trunk native vlan 4
If you connect your router to port 1
vlan 1 computer on port 2
vlan 4 computer on port 3
perform a show ip route you will see 2 directly connected routes.
The only work left to do will be your router with making static routes.
You can make 2 static routes on the router one pointing back to IP interface of the switch VLAN interface addresses.
-Tom
08-10-2012 12:07 AM
Hi Tom,
thanks for your patient.
You pretty much pictured my configuration.
The small difference is on gi1 where I'am connected to an umanaged switch with the router and the server (DNS,DHCP etc.)
I have one static route from the router to 172.16.2.101 for the 192.168.4.0 network. You mentioned 2 static routes on the router?
And I have a default route (0.0.0.0 to 172.16.0.55) to the router
And I can use the internet from the computer on gi3 (vlan4)
And I can ping the server 172.16.0.6 on vlan1 from gi3
But if I try to ping the router from gi3 (vlan4), I can see (on mirrored port with wireshark) on gi1 all 4 ping requests and all 4 replies. But on gi3 I get no replies. I see only the 4 requests.
Thanks again for your help
Andreas
08-10-2012 09:50 AM
Andreas,
How I am reading your information is this way;
The internet from 192.168.4.x works fine
I am able to ping from 192.168.4.x to the server
I ping from 192.168.4.x to the router LAN interface IP 172.16.x.x I see the request but I do not receive a reply
My interpretation:
The server is considered directly connected and does not make a routing decision, therefore the packet destination will go to the server and come back as the route is through the switch only. When trying to ping the router from 192.168.4.x to 172.16.x.x, the router does not know the path back to forward the packet to the 192.168.4.x network. Your static route may be adjusted to be something such as 192.168.4.0 /24 172.16.x.x <- IP of the VLAn1 interface. Now, keep in mind, if your default gateway is the router's LAN ip address, you won't ping the router. But, if the computer's gateway is the switch's vlan interface, it should be able to get a reply from the router LAN side.
-Tom
