SG300 bootloader corruption
Upgraded an SG300-20 from 1.1.1.8 to 1.3.7.18 this afternoon.  Bootloader was old enough I figured it probably should be updated as well.  No way to do it through HTTPS, so it's time for TFTP.  Documentation not great.  Start up TFTP server, log in via SSH, stumble around CLI looking for a 'show flash' equivalent, where is the filesystem in this thing?  Success with 'copy tftp://servername/sx300_boot-13506.rfb boot'  Reboot.  Ruh rho.
How do I recover this thing?  No examples of using xmodem in the guides that I can find.
thx...
Hi Murray, I did answer
Hi Murray,
I did answer yesterday same question at
https://supportforums.cisco.com/discussion/12163216/sg300-10mp-boot-code-update
please download my and follow my instruction.
Thank,
Moh
Last night, the switch was
Last night, the switch was not responding to pings or ARPing.  As of this morning, the IP stack has woken up, and all appears well.
#show version
SW version    1.3.7.18 ( date  12-Jan-2014 time  18:02:59 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V01
Odd that the switch would not pass traffic for over an hour after the boot file was updated.
Your Word Doc seems to suggest copying from the switch to the TFTP server:
#copy boot tftp://192.168.1.101/sx300_boot-13506.rfb
This morning I did the reverse order (just like last night):
#copy tftp://192.168.X.Y/sx300_boot-13506.rfb boot
13-Jan-2014 02:13:35 %COPY-I-FILECPY: Files Copy - source URL tftp://192.168.X.Y/sx300_boot-13506.rfb destination URL flash://BOOT
13-Jan-2014 02:13:43 %COPY-N-TRAP: The copy operation was completed successfully
Copy: 393232 bytes copied in 00:00:08 [hh:mm:ss]
Still wondering how I can show the flash contents or at least the boot file.
#show bootvar
Image  Filename   Version     Date                    Status
1      image-1    1.1.1.8     30-Aug-2011  10:46:34   Not active
2      image-2    1.3.7.18    12-Jan-2014  18:02:59   Active*
"*" designates that the image was selected for the next boot
#show version
Boot version    1.1.0.6 ( date  11-May-2011 time  18:31:00 )
HW version    V02
Hi Murray, So anything up and
Hi Murray,
So anything up and running now as how it should be?
Cisco Small business switch not support real IOS.  Cisco Small business use something different then IOS.  Cisco did that for limited switch use.  However SG300 switch hardware same as any 3650 catalyst switch.
Also please let me know new boot version
show version
Moh
I am aware that the firmware
I am aware that the firmware is not really IOS, but the similarities can trick you :)
Yes, the original switch did update:
#show version
HW version    V01
Still wondering if there is a command to show this kind of info on the boot file before you reboot the switch (similar to what show bootvar does for firmware)?
1036
