SG300 InterVLAN - Routing help!
Hi all, I have this network:
I have created the VLAN 1 and VLAN 2 in the SG300 and I can do a TELNET ping between them. The two routes 10.1.2.0 -> 0.0.0.0 and 10.1.100.1 -> 0.0.0.0 show up in the routing table. PCs connected to port 2 through 52 obviously are fine connecting to the Internet through the TMG firewall with a 10.1.2.1 gateway. I pointed the devices on VLAN2 to a gateway of 10.1.100.1 and no internet on VLAN2.
I'm stuck at this point. I know its a routing issue. I need the devices on the Netgear switch to connect to the internet and I also need interVLAN routing and connectivity. Thanks.
Green
Hi Mark, if I had to make a guess, the TMG is missing a static route pointing to the SVI of the SG300.
Read this topic for some input-
https://supportforums.cisco.com/thread/2123434
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hello
I really need help with Inter vlan routing via Kerio Controll 7.4.1.
I have several SF300-24P switches (IOS 1.3.0.62) and i have created a several VLAN's.
Vlans: Vlan 10, 100, 200 and interface vlan 213 (for management).
I can ping hosts in the same Vlan via this switches. From switch to host, port is in access mode and between switches ports is in Trunk mode
(also i had a problem here, trunk wasn't working untill i used command: switchport trunk allowed vlan add all).
Also port is in Trunk mode between KERIO and SW1 (switch). interface is in TRUNK mode from switch's side because i don't know how configure interface TRUNK mode on kerio.
On kerio i have configed one physical interface with IP - 172.16.0.1 255.255.255.0 and on the same interface i have created
VLAN 10, VLAN 100 and VLAN 200.
static IP's for this interfaces:
10.0.0.1 255.255.255.0 VLAN 10
192.168.100.1 255.255.255.0 VLAN 100
192.168.200.1 255.255.255.0 VLAN 200
On KERIO i have created DHCP Lease for each VLAN, but i cannot get IP's from DHCP. So i assigned static IP's  to computers
(for example for VLAN100 PC, VLAN 200 PC and so on) but they cannot ping each other when they are in different vlans, so inter vlan routing itsnot working. but with static IP on the PC, i can ping every VLAN's IP address on KERIO.
so pls tell me how i must configure inter vlan routing on kerio, is it possible?
or what must i do? where is my mistake? maybe when i put IP on pysical interface?
here is my configs and pls help and give me config example.
config-file-header
SW1
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator plaintext
vlan database
vlan 10,100,200,213
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname SW1
username administrator password encrypted 7fc3774d79570c81cda124d5dcf80b8ae0fcdd6c privilege 15
username cisco password encrypted 1defefd1f4a214009775b2c2b6b961a77da384b5 privilege 15
interface vlan 10
name Staff
interface vlan 100
name Cards
interface vlan 200
name AP's
interface vlan 213
name Management
ip address 172.16.213.1 255.255.255.0
no ip address dhcp
interface fastethernet1
description MANAGEMENT-VLAN
spanning-tree disable
switchport mode access
switchport access vlan 213
interface fastethernet2
switchport mode general
switchport general acceptable-frame-type untagged-only
interface fastethernet3
interface fastethernet4
switchport access vlan 200
interface fastethernet5
interface fastethernet6
switchport access vlan 100
interface fastethernet7
interface gigabitethernet1
description Direction-To-SW2      <--- This port is Trunk, but its not showing here for some reason.
interface gigabitethernet2
description Direction-To-KERIO  <--- This port is Trunk also.  i used: switchport mode trunk on both interfaces
exit
banner login
SW1
config-file-header
SW2
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10,100,200,213
exit
hostname SW2
interface vlan 10
name Staff
interface vlan 100
name Cards
interface vlan 200
name AP's
interface vlan 213
name Management
ip address 172.16.213.2 255.255.255.0
no ip address dhcp
interface fastethernet8
description Direction-To-SW1    <--- This port is Trunk also.  i used: switchport mode trunk
exit
banner login
SW2
i have excluded many interfaces because hey have same configs.
477
