SG300 not authenticated in Configuration Assistant
I am new to the SG300 series switch and am having an issue with the SG300-28 and the configuration assistant.  I have changed the IP, set up 3 devices with LAG and setup Telnet to work on the box. But in the Configuration Assistant the box will not seem to Authenticate, it always fails.  when I try to add the box it asks for a username and password to the "REALM ADMIN", not sure what that is and I think that is what is causing the box not to authenticate.  Everything else on the box is default for the most part.
Any help would be appreciated and thank you in advance.
402
