sg300 spurious media change messages
Brand new SG300-20, every now and then on console
12-Nov-2011 23:35:33 :%HAL_config_phy-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media (Unknown) on port gi19.
12-Nov-2011 23:35:33 :%HAL_config_phy-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media (Unknown) on port gi20.
12-Nov-2011 23:35:33 :%Fiber-I-SFP-PRESENT-CHNG: gi19 SFP status is present.
12-Nov-2011 23:35:33 :%Fiber-I-SFP-PRESENT-CHNG: gi20 SFP status is present
However these ports are not in use and have nothing installed...............
Firmware 1.1.2.0 (latest as of Nov 2011)
Any ideas?
Many thanks
Dave
Silver
Re: sg300 spurious media change messages
Dave
Do you have anything plugged into ports 19/20 ? You don't have any Mini-Gbic installed correct?
Whats your setup on the SG300-20?
Jasbryan
Nothing. They have never been used at all.
The only ports with anything in are Gi 1/2
NB There is no config in the switch for any other ports other than Gi 1/2..........
Sh run
vlan database
vlan 10,101,103
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 101
ip address 10.1.0.9 255.255.0.0
exit
interface vlan 10
ip address 10.10.0.100 255.255.0.0
exit
ip route 0.0.0.0 0.0.0.0 10.1.0.1
bonjour interface range vlan 1
hostname switch9571b0
username cisco password encrypted xxxxxxxx privilege 15
no snmp-server server
ip domain name xyz.org.uk
ip name-server  10.1.0.11 10.1.0.30
interface gigabitethernet1
switchport mode general
switchport general allowed vlan add 10,101,103 tagged
exit
interface gigabitethernet2
exit
interface gigabitethernet3
switchport mode access
switchport access vlan 103
exit
Silver
Dave,
Did you upgrade the switches firmware or did it come with the latest version 1.2.x? What was the pervious firmware version?  If you did upgrade the OS did you factory reset it after one of your upgrades?
Jasbryan
It was on 1.0.0.27 (as shipped).
I had a play around with that but noted from various posts that the CLI was available on the later f/w so downloaded that and upgraded.
I've cleared the config files several times but havent done a factory reset as such............I'll do that now and report back.
Dave
Did factory reset - and on the first startup prior to any config being applied.......
12-Nov-2011 23:34:45 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
Tapi Version: v1.9.5
Core Version: v1.9.5
12-Nov-2011 23:35:35 %INIT-I-InitCompleted: Initialization task is completed
12-Nov-2011 23:35:35 %Fiber-I-SFP-PRESENT-CHNG: gi20 SFP status is present.
12-Nov-2011 23:35:35 %Fiber-I-SFP-PRESENT-CHNG: gi19 SFP status is present.
12-Nov-2011 23:35:35 %HAL_config_phy-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media (Unknown) on port gi20.
12-Nov-2011 23:35:49 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 0
12-Nov-2011 23:35:49 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 0
Needless to say there is nothing in gi19 or gi20 .........
dave
1358
