05-22-2012 01:33 PM
Hi guys,
Hopefully I'm just being dumb and there is a simple answer to this. I have an SG300 authenticating telnet login to a RADIUS server. It allows me to log in at Priv level 1. when I try and enter Priv 15 mode, I'm prompted for a password which I don't appear to be able to set anywhere or know.
If I remove RADIUS and go back to Local authentication, telnet logs me in at Priv15 immediately. Anyone got any ideas?
Cheers
IW
05-22-2012 10:49 PM
Hi Iain,
You can create a enable password into the switch via the following command in blue.
switch38cbaf#
switch38cbaf#
switch38cbaf#conf
switch38cbaf(config)#enable password level 15 xxxxxxxx where xxxxxxxx is the password
switch38cbaf(config)#exit
switch38cbaf#wr
switch38cbaf#exit
C:\Users\testing> telnet 192.168.10.13 (my SG300-10P)
User Name:dialin (radius authentication passed)
Password:*********
switch38cbaf>enable
Password:xxxxxxxx
13-Nov-2011 03:43:54 %AAA-I-CONNECT: User CLI session for user unKnown over telnet , source 192.168.10.19 destination 192.168.10.13 ACCEPTED
switch38cbaf# enable password allowed me to get full control
I have opened a case with the Small Business Support Center (SBSC) as i did notice a couple of issues.
see if this helps
regards Dave
05-23-2012 09:14 AM
Hi Dave,
I tried that yesterday and again just now (to make sure I wasn't being stupid) and it still seems to reject the password I've typed in.
When connected to CLI as a local Priv15 user:
"SG300-10(config)#enable password level 15 password"
Then flick authentication over to RADIUS.
User Name: xxxxxx
Password:*********
SG300-10>show priv
Current privilege level is 1
SG300-10>en
Password:********
Password:*********
Password:********
authentication failed
SG300-10>
For reference:
SW version 1.1.2.0 ( date 12-Nov-2011 time 23:34:26 )
Thanks for your efforts so far. Any further help greatly accepted.
Cheers
Iain.
05-23-2012 09:28 AM
OK, fixed it
From CLI as a Priv15 user,
conf t
line telnet
no enable authentication
Thanks for your help in getting this going.
Iain.
