SG300, telnet and RADIUS authentication.
Hi guys,
Hopefully I'm just being dumb and there is a simple answer to this.  I have an SG300 authenticating telnet login to a RADIUS server.  It allows me to log in at Priv level 1.  when I try and enter Priv 15 mode, I'm prompted for a password which I don't appear to be able to set anywhere or know.
If I remove RADIUS and go back to Local authentication, telnet logs me in at Priv15 immediately.  Anyone got any ideas?
Cheers
IW
Everyone's tags (4)
Re: SG300, telnet and RADIUS authentication.
Hi Iain,
You can create  a enable password into the switch via the following command in blue.
switch38cbaf#
switch38cbaf#
switch38cbaf#conf
switch38cbaf(config)#enable password level 15 xxxxxxxx  where xxxxxxxx is the password
switch38cbaf(config)#exit
switch38cbaf#wr
switch38cbaf#exit
C:\Users\testing>  telnet 192.168.10.13   (my SG300-10P)
User Name:dialin               (radius authentication passed)
Password:*********
switch38cbaf>enable
Password:xxxxxxxx
13-Nov-2011 03:43:54 %AAA-I-CONNECT: User CLI session for user unKnown over telnet , source 192.168.10.19 destination  192.168.10.13 ACCEPTED
switch38cbaf#   enable password allowed me to get full control
I have opened a case with the Small Business Support Center (SBSC) as i did notice a couple of issues.
  • There is no option within the GUI to create a enable password,  had to be done via CLI.
  • I have a issue with authentication first  trying local and then radius.
see if this helps
regards Dave
Hi Dave,
I tried that yesterday and again just now (to make sure I wasn't being stupid) and it still seems to reject the password I've typed in.
When connected to CLI as a local Priv15 user:
"SG300-10(config)#enable password level 15 password"
Then flick authentication over to RADIUS.
User Name: xxxxxx
Password:*********
SG300-10>show priv
Current privilege level is 1
SG300-10>en
Password:********
Password:*********
Password:********
authentication failed
SG300-10>
For reference:
SW version    1.1.2.0 ( date  12-Nov-2011 time  23:34:26 )
Thanks for your efforts so far.  Any further help greatly accepted.
Cheers
Iain.
OK, fixed it
From CLI as a Priv15 user,
conf t
line telnet
no enable authentication
Thanks for your help in getting this going.
Iain.
2882
