Community Member
SG500-28P SNMP query for individual port power output?
Is there a way to ask the above switch how much power it's supplying to various ports?
I've found some stuff in POWER-ETHERNET-MIB, but it's only the main power supply and the up/down status of the various ports.
It looks like what I want is
http://www.oidview.com/mibs/9/CISCO-POWER-ETHERNET-EXT-MIB.html
but my SG500 tells me:
snmpwalk -v2c -cpublic serverswitch  1.3.6.1.4.1.9.9.402
CISCO-SMI::ciscoMgmt.402 = No Such Object available on this agent at this OID
Is there any other trick I'm missing?
Thanks!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Green
Re: SG500-28P SNMP query for individual port power output?
Hi w_smith, attached is a console log of all MIB supported by the switch.
Below are the POE object names found on the switch.
      lldpXMedLocXPoEDeviceType
      lldpXMedLocXPoEPSEPortTable
      lldpXMedLocXPoEPSEPowerSource
      lldpXMedRemXPoEPDTable
      lldpXMedRemXPoEPSETable
      lldpXMedRemXPoETable
      rlPhdNumberOfPoeUnits
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
-Tom
Community Member
Thanks Thomas!
Unfortunately, it looks like lldpXMedLocXPoEPSEPortTable should do something useful, but:
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.49 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.50 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.51 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.52 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.53 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.54 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.55 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.56 = Gauge32: 130 tenth of watt
LLDP-EXT-MED-MIB::lldpXMedLocXPoEPSEPortPowerAv.57 = Gauge32: 38 tenth of watt
This switch is currently supplying:
4500
9100
5600
5300
4900
milliwatts.
Ah, but I did find some stuff under:
snmpwalk -v2c -cpublic serverswitch rlPethPsePortTable
though I can't parse the details, must be missing a MIB file...
Community Member
Ah, OK, so:
rlPethPsePortOutputPower
aka
.1.3.6.1.4.1.9.6.1.101.108.1.1.5
is the relevant OID, and specifially:
.1.3.6.1.4.1.9.6.1.101.108.1.1.5.1.{49-72 inclusive)
Where the last .1. is the unit number and .49 thru .72 are the 24 gigabit ports.
I'm going to credit Tom with the correct answer, or at least the posting that lead me there.
Community Member
And for what it's worth, a similar thing works on the SF300-24P, though the port numbering is slightly different:
snmpwalk -v2c -cpublic 192.168.1.160 1.3.6.1.4.1.9.6.1.101.108.1.1.5.1
CISCOSMB-MIB::switch001.108.1.1.5.1.1 = INTEGER: 9900
Green
Hi w_smith, here is the SX300 mib variables attached. Hope this will provide additional features for you.
-Tom
Community Member
Not sure I can parse that console log, but if you can do something like:
You should see the details of what the port numbering scheme are and what details are reported by the switch.
Let us know!
3362
