SG500 - Issues with PoE
Hola, I've 3 switch units of the same model, 2 of them presents the same issue.
The PoE devices I plugged in them aren't powered.
Checking the switches via CLI I could see this:
ARBUEDSW0-2#show power inline
Port based power-limit mode
Inrush Test: Enable
Legacy Mode: Enable
Unit Power Nominal Power Consumed Power Usage Threshold Traps Temp (C)
1        On      375 Watts         0 Watts     (0%)              95           Disable    37
Port Powered Device State Status Priority Class
gi1/1/1                          Auto Fault low class4
gi1/1/2                          Auto Fault low class4
gi1/1/3                          Auto Fault low class4
gi1/1/4                          Auto Fault low class4
and this:
ARBUEDSW0-2#show pow inl gi1/1/1
Time range:
Power limit: 30.0 W
Inrush Test: Enable
Legacy Mode: Enable
Port Status: Port is off - power budget exceeded
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
Invalid Signature Counter: 0
The power consumption is zero and all the ports have PoE status = Fault by the same reason: power budget exceeded.
Due it's happens to 2 switches at the same time I'm suspecting of a wrong setting but I can't find it.
Please advise a way to troubleshoot this issue.
Thanks in advance
1 REPLY
VIP Purple
That sounds like a hardware
That sounds like a hardware issue (I assume you have tried giving the switches a power cycle).  I'm guessing a PoE power supply has failed.
93
