SG500 - NTP IP-Helper
The same problem that plagued the SGE series switches also does not work on the SG500 series switches.
Trying to UDP relay port 123 (NTP).
For what it's worth, I think I'm having the same problem you are.  I'm basically able to resolve it by having a local Linux box running smcroute (http://www.cschill.de/smcroute/), though that's obviously not the most elegant solution.
Green
Re: SG500 - NTP IP-Helper
Hi, the reason the service is busy is because it is being utilized. If you navigate to Security -> TCP/UDP Services you'll notice the port 123 as an active service on the UDP section.
I guess the solution would be to disable UDP on the switch but the next question is how?
I'm trying to figure it out now.
Edit- I can't see a way to make the UDP 123 go away but I had a thought. Perhaps use DHCP option 4 within the switch DHCP server. Of course this may have other unwanted implications but I do not see a work around.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Could you raise this issue to engineering?
I mean, its one of the predefined services.
Plus this is a pretty common service to propagate.
Green
Yeah I have. I'll post back when I hear something (so long as my memory doesn't fail me)
-Tom
Thanks.
No problem, I appreciate your efforts.
334
