SG500, Questions about QoS Settings
Hi all,
have here a SG500 with latest Firmware.
I would like to change "CoS/802.1p to Queue Map" default settings i want to use queque 8, but i get this warning.
Queue 8 is reserved for stack-control traffic. Using this queue for user traffic might disrupt stack stability. Do you want to continue?
Interestingly, queque 8 is specified in CLI_500 tutorial as a default value:
  1. Default Configuration
    The default CoS value mapping to 8 queues is as follows:
    • CoS value 0 is mapped to queue 1.
    • CoS value 1 is mapped to queue 2.
    • CoS value 2 is mapped to queue 3.
    • CoS value 3 is mapped to queue 6.
    • CoS value 4 is mapped to queue 5.
    • CoS value 5 is mapped to queue 8.
    • CoS value 6 is mapped to queue 8
    • CoS value 7 is mapped to queue 7.
The same behavior with "DSCP to Queue Map"
Therefore the question, can i use the "queque 8" or is this critical ?
thx
Stefan
Green
Hi Stefan, it is not critical if you're not using the stack function.
If you remove the queue 8 or occupy it some other way in a stack environment it may have adverse effects for how the stack interops between units or how data relays between the units.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom, thanks for fast answer.
hmm, i have 4 SG500 units with stack funktion then it is better do not use queque 8.
But why different default values (SG500 <-> Tutoeial) described in the cli_500 tutorial (CoS and DSCP) ?
Understanding question
Why is DSCP values 16 (why not queque 3 or 4), 24,40 the in the high queque 7, the same with DSCP values 48-63 ?
Stefan
1263
