Community Member
SG500 "no ip redirects"
i want to disable the ICMP redirect messages, but i can't find the command "(no) ip redirects". Are there other commands ?
1 REPLY
Community Member
Hi Thomas, Did you try config
Hi Thomas,
Did you try config extended ACL block ICMP?  All you need to do conifg extended ACL black ICMP save your config reload your switch
Moh
224
