SG500 - Router Advertisement Bug
DJX995
Level 3
Level 3
The following settings reset to "False" on reboot.
I need them to persist across reboots.
Managed Address Config flag
Other Stateful Config flag
Only flash logs are:
21474831812013-May-02 09:59:54Error%INIT-E-ApplErr: Errors occurred during initialization
21474834142013-May-02 09:57:44Error%MNG_DIAG-E-DIAGATINIT: Init: SNMPCenG_setVariable - init: Bad value for configuration item ipv6RouterAdvertTable, field rlIpv6RouterAdvertIsCurHopLimitUserConf igured
21474836472013-May-02 09:57:44Error%MNG_DIAG-E-DIAGATINIT: Init: SNMPCenG_setVariable - init: Bad value for configuration item ipv6RouterAdvertTable, field rlIpv6RouterAdvertIsCurHopLimitUserConf igured
2 Accepted Solutions
I have sent notification to the product management and escalation manager to investigate further. From the appearance, it seems to be a bug. However, there may be some sort of dependency we (you and I) may not be aware of. I'll let you know when I hear something back.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hey, to follow up this, it has been reproduced in the lab. If you configure the feature through CLI it is persistent. This is limited to the GUI only.
-Tom
5 Replies 5
Tom Watts
Hi Fratiani, I'm finding the same results, for the life of me I can't make that configuration stick.
-Tom
Ok, thanks for testing.
I have the same exact problem with my SonicWALL and I filed a report with them.
If you work for Cisco, do you think you could file a bug report?
I do not have support on my unit or I would do it.
Thanks.
-Tom
Thanks man
-Tom
