SG500 stacking question
Hello we have 3 SG500 switches in my company's network, my question is can we stack them using a combination of udp and sfp cables? The problem is that the first switch is approximately 60 meters away from the others two.
Everyone's tags (3)
Hi , Stacking is supported
Hi ,
 Stacking is supported with twinax cable , not with UTP copper cable or SFP fiber cable .
 Maximum Supported is 10 meter ,
Stack Connection Options
500
500X
500
5G copper – SFP-H10GB-CUxM
1G fiber or copper – MGBxxx
1G Base-T – embedded RJ45 (S1/S2)
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
Sandy
Thank you for your answer! I
Thank you for your answer! I found a link to purchase the 5G copper – SFP-H10GB-CUxM although i didn't find anything for the 1G Base-T – embedded RJ45 (S1/S2), maybe i missed something. If you have a link where i can find it, it would be awesome. Thanks again for your time.
872
