SG500X - CLI command to disable "Administrative Auto Smartport"
I am looking for the CLI command I would use to disable Administrative Auto Smartport, which on the SG500X is found under SMARTPORT > PROPERTIES > radio button "disable"
I would want to do this across a range of ports, e.g. 1 - 48, so if someone could post the complete command, I would be grateful
I am used to using "int range" on a Catalyst switch, but this doesn't seem to work on the SG500X.
Appreciate I can log into the GUI and do it with a couple of clicks, but I have a copy/paste txt file I use in TELNET to set up my VLAN's, and would like to also be able to disable this feature using CLI as it's one less thing to worry about.
Many thanks in advance.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi, here are examples of
Hi, here are examples of commands:
switchxxxxxx(config)# interface range gi1/1/1-20
and
switchxxxxxx(config)# no macro auto smartport
and CLI guide is here:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/cli_guide/CLI_500.pdf
-- please remember to rate and mark answered helpful posts --
1 REPLY
and
729
