04-18-2012 06:37 AM
I have some doubts about the SGE2000 not located in DataSheet or internet:
What standard Memory Switch?
Do you have any expansion slot?
Supports Per VLAN Spanning Tree (PVST)?
Supports Port Secure?
Supports configuration templates in Gigabit Interfaces?
The LED indicators show the bandwidth?
04-19-2012 06:39 AM
Hello Alrbastisa,
The SGE series of switch are part of the small business model and do not have the same feature set as our enterprise switches.
The small business series does not have expansion slots.
They do not support PVST.
The ports do have PVE.
The LEDs will show if the port is running 10/100 or gig speed but not the amount of bandwidth.
If you are looking for a small business switch, I highly recommend the Sx300 or Sx500 series.
04-19-2012 08:15 AM
Hi Robert,
Thanks for your reply.
I'll see if the switches that you recommended will suit me.
Alrbatista
