SGE2000 inter vlan routing problem
I have the following problem with routing between vlan on SGE2000 switch configured in L3 mode:
I have 2 locations connected througn vpn with the following ip's:
HQ class configured on cisco router (i do not have access on that because is the router of my internet provider): 192.168.50.0/24, gw on 254
Remote site (same as HQ with access): 192.168.51.0/24, gw on 254
My internal class on HQ is 10.0.0.0/24 with gw on 10.0.0.1
Both of classes are conected in SGE2000 switch. The config on the sw:
vlan database
vlan 10,20
exit
interface ethernet g1
switchport access vlan 10
exit
interface range ethernet g(2-24)
switchport access vlan 20
exit
interface vlan 10
name VPN
exit
interface vlan 20
name PCs
exit
interface vlan 10
ip address 192.168.50.1 255.255.255.0
exit
interface vlan 20
ip address 10.0.0.254 255.255.255.0
exit
ip route 192.168.51.0 255.255.255.0 192.168.50.254
The 10.0.0.1 IP is connected in port 19 which is on vlan 20.
Main problem is that i cannot ping from internal class (10.0.0.0/24) in provider access class (192.168.50.0/24) and the vpn class (192.168.51.0/24)
From the sw i can ping in all the above classes.
Thanks!
Everyone's tags (3)
957
