Community Member
SMALL BUSSINESS NOT FOUND IP ROUTE
hi everybody i need help my cisco small bussiness SG-500 52P not found command IP ROUTE.
the cause is an electrical cut, my small bussines reset to factory
1 ACCEPTED SOLUTION
Green
Hi Rafael, can you also verify the switch is in switch or router mode? It is possible when lost power, the config was reverted to the last known config (last time the config file was saved).
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
Hi Rafael, there's not enough information provided. Do you have multiple IP interface configured on the switch? If so, show ip route should display the default routes especially if there is link state on the vlan interfaces.
-Tom
Green
-Tom
Community Member
602
