11-22-2013 06:23 AM
I'm searching the OID for memory, but I can't find them. I found the mib for SGE20x0 which works also for the switcch SFE2000 here
http://software.cisco.com/download/release.html?mdfid=282414067&softwareid=283415684&release=3.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest , but there is no OID listet for memory. Is there no OID for memory available?
Jürgen
Solved! Go to Solution.
11-22-2013 08:42 AM
Hi Juergen, the information contained within the link is the documented and supported information.
If the OID / object name is not listed that you desire it is essentially unsupported.
If you haven't already, you can try to walk the database and parse results to see if there's anything close to what you'd like.
-Tom
Please mark answered for helpful posts
11-22-2013 08:42 AM
-Tom
11-22-2013 08:49 AM
Hi Tom. Thanks for your answer. I have included the mib in linux, browsed by snmpwalk and greped by mem, but have nothing found.
Jürgen
