Community Member
SRW224G4P only work on default VLAN 1
I have a SRW224G4P linksys switch with the following configuration.
VLAN 10 (untagged) excluded for port 1,2
VLAN 100 (tagged) included for port 1,2
VLAN 200 (untagged) included for port 1,2
PVID set to 200 for port 1,2
When I connect PCs onto port 1,2, they cannot ping each other.
If I set the PVID for port 1,2 to 1 (the default VLAN), then it will work.
Are there anything I missed in order to use VLAN 200 for the PCs ??
Any input most appreciated. KL
279
