SRW224G4P_POE_UART_Loopback_Test_FAIL
I have a switch that when turned on the System light starts blinking orange. When I connected to the switch with the console cable I got this:
Image Loader 1.0.1
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... FAIL
DRAM Test .................... PASS
Timer Test ................... PASS
Something is wrong.
------------------ DONE ---------------------
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
Runtime 1.0.2
Pass
root init done
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
stacking DB: unit = 0, module type = 0
Finish Set Transition mode ...
Enter Transition mode ...
Here the boot process stops no matter how many time I restarted the switch.
Is the switch repairable wiht some software or is the POE UART Loopback Test ....... FAIL a hardware problem?
best regards
Tomaz
Silver
Hello Tomaz,I have seen this
Hello Tomaz,
I have seen this issue get resolved if you can manage to factory default the switch, however usually this will end up being a hardware replacement.
If you are still covered under your warranty go ahead and give us a call at the SBSC and we can get an RMA created for you.
Cisco Small Business Support Contact Numbers
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
I have done the factory reset
I have done the factory reset and it did not help. Warranty is not covered any more so the switch is roaming in the trash.
Thank you for your help.
44
