Community Member
Switch sg 200 trunk and DGateway query
i'm using cisco sg 200 switches(24port ,48 port with 2 GBIC (rj-45 port and spf port) on each). in a small office network.i've attached the diagram.
please answer the below queries.
1)what should be the default gateway for both switches(coz im not using any router).
2)all the pc's are in Server.
3)i have connected the two switches using a crossover at gbic(rj45-port).and the remaining are straight connection from switch to all pc.what should i do inorder to config the trunk port.
as there are small series switches. there is no con port? and when i access the switch using the device ip there is no option to config default-gateway in that.
and on pc's i have enter the device ip as default gateway. only few pc's can ping each other. rest are not successful in getting the ping reply.
plz replly
Is it correct you have no configuration on the switches?
Do you have Internet or other networks that need to be reached or you just want all workstations to reach each other?
You do not need or want a default gateway if all workstations are assigned ip addresses is the same subnet.
-- please remember to rate and mark answered helpful posts --
