Switchport access removed.
Hi all,
I have a switch SG500 28G POE stackable. See my config below in my switch and this is the corect configuration with no issue.
interface gigabitethernet1/1/2
description Dlink-SW-GSD-4-IPphones-No5
switchport trunk allowed vlan add 20,440
This port has been used for iphone for vlan 20 and 440. Suddenly just when the issue comes, iphone cannot be used and i check the configuration as shown below.
Looks like it has been deleted automatically. If you have any idea why this occue it would much appreaciated.
Ashraf
1 ACCEPTED SOLUTION
Green
Hi Mohd, if the configuration is 'disappearing' it is probably because the smart ports over write your configuration which is the likely result you have an upstream device advertising something different.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Update: I added it back to this interface same configuration and write memory. Its still occur this issue.
Hope this will be more clear description.
Thank you.
Ashraf
Try the following commands
switchport mode trunk
switchport trunk native vlan id (just to be on safe side)
Green
-Tom
Hi Tom,
Bravo. I tried to disable smartport for port gigabitethernet1/1/2 for 3 days and it works.
Thanks a lot.
-ashraf
311
