02-03-2014 02:25 PM
I do not find much information about the POE-IN port 1 on the SG200-08. Will I be able to power a SG200-08 switch from a POE port on a SG200-26P?
02-03-2014 04:09 PM
Hi Ivar, yes, this switch does have a function to power another sg200-8 with POE via port.
-Tom
Please mark answered for helpful posts
02-05-2014 02:29 PM
Ivar,
The SG200-08 is designed to be powered by PoE when used in remote locations where AC power is not available.
- Marty
11-04-2014 07:57 PM
Is it anywhere documented on which type of POE Input voltage is needed for this switch?
The question is because I do have a 24v POE injector that I'd like to use to power this switch, but in the specifications this switch is supposed to receive only 12v.
Any recommendations? Will I burn the switch if I connect a 24v POE injector in port 1 ?
Tks for your help
Diego
11-05-2014 08:03 AM
Hi Diego,
The 12V input is for a power supply (wall wart). The switch will negotiate with the PoE injector and get the power that it needs. It should work without issues as long as the injector is standard.
- Marty
11-05-2014 03:18 PM
The injector I'm planning to use is the one that comes with a Ubiquity Access Point.
It's described here: http://www.ubnt.com/accessories/poe-adapters/
