Community Member
VLAN config on cisco sg300
I am using a couple cisco sg300 28P switches along with a sonciwall firewall/router. The sonicwall was already in place and working so they didnt want to replace it. I understand how to configure the vlan on the sonicwall, but could use some help on the cisco. I would basically like to create 3 vlans, 1 default for management, 2 for pc's on lan, and 3 for the cisco spa504g phones/'voip. Would i just go into the vlan managment, configure the 2 new vlans and give them two id's? These offices have one network drop, so the phones and pc's will be sharing the switch ports, however the phones have a setting to configure the vlan id so they know which one theyre on. Is there anything i need to do after that? I want to make sure that vlan 3 has the highest priority becuase its voice, is there some qos configurations i need to make on that switch as well? Also, the port that links the two cisco swtiches together, does that need to be set as "trunk" port? I understand what vlans are, but its just the first time ive run into these cisco models. Thanks in advance for any help...
Everyone's tags (6)
1426
