WS-C2960-8PC-S?
Are there any plans to introduce a small fanless 2960 switch with 8 PoE 10/100 ports?
Would fill the aera between the ESW-520-8 and the 3560-8PC perfectly :-)
Maarten-Jan
Re: WS-C2960-8PC-S?
What about the ESW-520-8P - PoE on that one.
Or you could go for a SD208P - 8 Ports 10/100, with 4 of on them on PoE
Both fanless
Re: WS-C2960-8PC-S?
Hi Maarten-Jan,
Also, check out the SFE1000P.  It's a fanless eight port 10/100 POE switch.
regards Dave
Re: WS-C2960-8PC-S?
Preference for an IOS switch and the 2960 feature set. The 3560 is a bit high priced. Features like HSPR and Inter-VLAN IP routing are not required. The small business switch (ESW and lower) don't fit. The 2960-8PC would be great :-)
Maarten-Jan
940
