01-13-2018 10:11 AM - last edited on 03-25-2019 10:30 PM by ciscomoderator
Hi Guys,
i have recently purchased a cisco uc520 which hasn't yet arrived,
i'm struggling to find any information on configuring this device, i'm not familiar with the command line interface.
is there any other way of configuring the device or can anyone help with the command line side of things?
thanks in advance :)
Lee
01-15-2018 08:28 AM
You can find Getting Started/Quick Start guides here:
One option is to use Cisco Configuration Assistant to configure. CCA has a GUI interface and can configure the basic components (DNs, call routing, VM, etc.)
As I'm sure you are aware the UC520 and CCA are no longer Cisco supported products.
Brandon
01-15-2018 09:46 AM
hi Brandon,
do you havce any idea on how i connect the uc520 with the configuration assistant without a console cable?
regards,
Lee :)
01-15-2018 10:28 AM
The default configuration of the UC520 has a DHCP server configured to hand out addresses in the subnet 192.168.10.1/24. You would connect your PC to one of the switchports and connect to 192.168.10.1 via CCA. If the default config has been wiped, you will need to connect via console cable to assign an address and setup a username/password before connecting with CCA.
Brandon
