541n question(s)
Does anyone know how the license model works in the 541n
clusterable AP's ? I have gathered that they can be clustered up to 10
APs. And there is info on CCO that it supports upto 100 users. I need
to know if there is a hardware limit of some sort or is it a guidance of
how many users you should expect the system to carry in a good quality.
regards. Kristjan Edvardsson
Wireless Systems Engineer
Sensa ehf. Cisco Gold Partner
1 REPLY
Re: 541n question(s)
In the Data Sheet, they make specific mention of CCA supporting up to 10 AP's:
Cisco Configuration Assistant simplifies the task  of configuring and managing the AP 541N as well as the entire Cisco  Smart Business Communication System. Cisco Configuration Assistant  supports up to 10 Access Points
So I wonder if this limitation is purely software, and that if configured via the web interface, that more than 10 devices can be used?
As far as the 100 users go, that is simply the "advisable" range for the SMB and SMB Pro products. When you get into larger user bases, you are expected to get into Cisco's regular offerings.
295
