AP WAP 321 with RADIUS server
I want to use RADIUS server with WAP 321 as the picture below.
Question
1) Does user has to reauthenticate again from AP1 -> AP2 in the cluster ?
2) If I use FreeRADIUS with WPA or PEAP mode. Does user need to connect another Wifi profile again?
If you have a recommendation, please help me for this issue.
Thank you very much.
1 REPLY
Bronze
Dear Thunthorn,
Thank you for reaching Small Business Support Community.
When you configure Single Point Setup on a device (cluster) , settings from that device (whether they are manually set or set by default) are propagated to other devices as they join the cluster, therefore the hosts should not have to re-authenticate as they move on from AP1 to AP2 as long as the RADIUS Server configuration is the same.
I hope this answers your question and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
819
