AP500 connect external outdoor antenna
is it posible to connect an outdoor antenna to the AP540?
And if Yes, which ones will fit?
Many Thanks in advance.
@lex
1 ACCEPTED SOLUTION
Re: AP500 connect external outdoor antenna
If you are referring to the AP541N, the antennas are detachable, however we do not specifiy/recommend any external or outdoor antennas for this unit.
Best Regards,
Glenn
Best Regards,
Glenn
Glenn,
thanks for this info. So it's up to me to test this for myself.
@lex
Please post back if you find results...
759
