Community Member
AP541N Questions
Im looking at getting a few of these AP's but have some questions, any help would be appreciated.
How many SSID's can I have active at a time (I think its 16 but I couldn't find a definitive answer)
1. If I use "Clustering" does roaming just work?
2. In clustering do the multiple SSID's still work?
3. Can each SSID have its own encryption?
     I'm looking to deploy these at a retail location and need to make sure I can give access to my staff, customers, and a secure network for my wireless inventory system (just some handhelds). So roaming is important.
Thanks for any help.
-Eric
1 REPLY
Bronze
Re: AP541N Questions
Hello and good evening,
I would suggest to check out the recorded VOD or at least the pdf by clicking here:
PDF:
https://www.myciscocommunity.com/docs/DOC-13933
Recording:
https://cisco.webex.com/ciscosales/lsr.php?AT=pb&SP=EC&rID=41707292&rKey=8dab4deeab333727
This was a pretty good one on the AP541 with a lot of info on the product and clustering / roaming.
Also, all of our weekly webinar sessions and past recordings can be found off of this link:
https://www.myciscocommunity.com/community/partner/smallmediumbusiness
From your list:
I might suggest to work with your sales person / SBMM and get some gear you can use for your site survey and to get familiar with .
HTH,
Andrew Lissitz
1291
