AP541N & SA520W Support Wireless WPA2-PSK Bridging?
kevinfor
just wanted to know if the SA520W can wirelessly bridge (Workgroup bridge, WDS, etc -don't care which) to either an AP541N or AP1252... using WPA2-PSK
the 2 seperate examples would be
Internet --->SA520W --(Wireless 30 feet) --->AP541N -->ESW-540-24P-K9
internet --->Sa520W --(Wireless 30 feet)----> AP1252 -->ESW-540-24P-K9
internet --->AP1252 ---(Wireless 30 feet) ---->SA520W-->ESW-540-24P-K9
in other words do you just go into the config of the SA520W ... enter in an existing SSID name and the WPA2-PSK  password and it joins that wireless network.
lastly does the SA520W support POE to the switch above or only the AP541N
thanks again
Kevin
stef.Andries
[bump]
Same question. I would like to bridge the SA520W to an AP541N via a wired connection, since WDS doesn't seems to be an option.
Anyone ?
