Bridging VLANs with WAP200E
I'm trying to bridge two buildings with two WAP200E. The connectivity is fine, but I'm only able to get one VLAN through the bridge. That is the default VLAN 1 wich is untagged. I have two additional VLANs wich is tagged. I can not get these two through the bridge. I have set up a single SSID, and enabled VLAN. I have also tried to set up more than one SSID, mapping each VLAN to separate SSID's, but bridging several SSID's between two AP's make the AP's loose connectivity periodically. What would be the propper way of bridging several VLANs between two WAP200E ?
1 REPLY
Re: Bridging VLANs with WAP200E
I have exactly the same problem, does anybody know if WAP200 supports wireless bridging of multiple VLAN's?
395
