Community Member
Can WAP200E repeat with other AP models?
Hi guys,
Can WAP200E repeat with other AP models? I think it should be working with other models as the signal should be the same in different APs. Is that correct ?
Henry
1 ACCEPTED SOLUTION
Community Member
Re: Can WAP200E repeat with other AP models?
Sir,
Thank you for visiting Cisco Community Forum.
Note: For the AP Client and Wireless Bridge Modes, the remote access point must be a second Linksys Wireless-G Access Point. For the Wireless Repeater mode, the remote wireless bridge must be a second Linksys Wireless-G Access Point or Wireless-G Router.
The WAP200E uses WDS (http://en.wikipedia.org/wiki/Wireless_Distribution_System) - WDS may be incompatible between different products (even occasionally from the same vendor) as it is not certified by the Wi-Fi Alliance
http://www.cisco.com/en/US/products/ps10047/products_qanda_item09186a0080a38f1f.shtml
It may be possible to bridge different models if they also use WDS where you can match up the MAC addresses on both sides.
Jeff.
Community Member
Sir,
Jeff.
Community Member
Thanks Jeff. Appreciated...
1045
