Captive portal + Dhcp
Hi guys,
Could someone tell me if there is an Access point with captive portal and dhcp server?
I need a device wich authenticates guest users and give an ip address.
I know the controlled based solution do this but I just need an access point.
Thank you
1 REPLY
Bronze
Dear Partner,
Thank you for reaching Small Business Support Community.
Unfortunately there is no Small Business access point to accomplish DCHP server functionality.  I suggest you to look for an enterprise level device for that matter and please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
425
