Client unable to connect to new created SSID on WLC 2504
Hello all,
I am facing an issue on Wireless controller 2504, I created a SSID and assigned an interface and set preshared key for (WPA + WPA 2), i can see SSID broadcast when i am trying to connect it pop-up to enter key, When i enter the screen pop-up cannot connect.
Sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
Last Reset....................................... Software reset
System Up Time................................... 13 days 10 hrs 29 mins 24 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Everyone's tags (2)
Its connected now but taking
Its connected now but taking too much time while switching between two SSID, i have to disconnected and then connect and then wait after 5 mins device will able to connect with New SSID..Kindly help cant figure it out whats going wrong
VIP Purple
I hope you would have
I hope you would have resolved the issue ...
There is feauture called  FAST-SSID on WLC. Enable it and give a try!!
Login to WLC, Click on Controller > General, enable Fast SSID Change.
Don't forget to rate helpful posts
467
